Date/Time: Mon, 20 Jan 2025 20:52:10 +0000
bitmex feed and eurex feed simultaniously?
View Count: 1217
[2017-12-29 01:12:46] |
User541842 - Posts: 34 |
hi there, is it possible to have the bitmex feed running on sierra chart for trading coins (dont like browser based platforms) and my cqg feed to trade the bund at the same time? if yes, how is this done? |
[2017-12-29 09:38:56] |
First you will need a direct account to access crypto currencies like BitMEX. Refer to: Direct Sierra Chart Account We have added BitMEX to the list of symbols when using CQG. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-29 09:40:03
[2017-12-29 10:26:14] |
did that, but when trying to open a chart via find symbol, i actually dont get any symbols pressed get symbols, but nothings happening. |
[2017-12-29 10:31:40] |
solved, not a direct account i have.
[2017-12-29 22:17:20] |
OK it probably is because you are on the Advanced Service Package and that is the reason why you have access to it.
[2018-06-22 16:56:21] |
User724413 - Posts: 1 |
Hi, Is simultaneous trading of EUREX and BITMEX also possible with the low cost CTS connection (with direct account)? or do I need to buy a second connection (sth like 10 symbols)? Thanks in advance! |
[2018-07-07 11:14:53] |
You need separate installations of Sierra Chart for this. Refer to: Using Multiple Data and Trading Services at the Same Time You do not need a second market data connection for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
