Date/Time: Sun, 24 Nov 2024 03:44:21 +0000
Trading DOM - Showing the Volume coming through
View Count: 3039
[2013-09-19 09:14:29] |
Futurestrader77 - Posts: 126 |
Hello, I would like to know if it is possible to show the volume coming through at each price in the DOM (like it shows the DOM from CTS or X_Trader). I discovered a picture showing this with Sierra (the red circle shows the volume traded at each price) but I don´t get it. Thanks! |
[2013-09-19 09:46:47] |
Are you referring to the Volume Profile that is shown on the Trade DOM showing the total volume of each price level? If so, this is documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#TradeDOMVolumeProfile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-19 09:56:04] |
Yes, beside of the volume profile you can see the number 1 in the red circle I made. I´m assuming that this is the volume coming through at the bid, in the T&S you can see it too: 1 contract traded at the bid at 1493,50. I got this image from BigMikeTrading but don´t remember the thread so I´m asking here. It would be nice to have this future in the DOM. I´ve added another picture where you can see how the DOM from CTS-T4 handles this. Thank you! |
DOM CTS-T4.PNG / V - Attached On 2013-09-19 09:54:10 UTC - Size: 55.65 KB - 1050 views |
[2013-09-19 12:15:58] |
crazybears - Posts: 314 |
Hi try : menu->Trade-> Customize TradeDom Columns ->add Cumulative last size |
[2013-09-19 12:32:07] |
That´s it! Thank you very much crazybears! Have a nice day! ,-)
