Date/Time: Fri, 17 Jan 2025 19:40:15 +0000
Cleaning temporary drawings on charts
View Count: 963
[2017-12-28 14:41:06] |
User23815 - Posts: 210 |
Can you please point me to info on how to clean temporary drawings on charts, without erasing ones that I have as permanent. For example; erase all elipses. Erase all trendlines. But I have some horizontal lines, some locked, some not, that I want to remain. I believe drawn items are assigned numbers but I don't know an easy way to identify and match them to the drawings on the chart. Thanks
[2017-12-28 19:08:24] |
We recommend using the Manage Chart Drawings window: Chart Drawing Tools: Manage Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-28 19:08:32
