Date/Time: Sun, 24 Nov 2024 03:22:20 +0000
Changing time frames and Pivot Points
View Count: 1301
[2013-09-19 02:29:14] |
User123496 - Posts: 27 |
Hi, I see where I can just duplicate a chart from within it, but how do you change the time frame on the duplicate? I duplicated a 5 min. chart and want to change it to a 3 min. chart. Also, I want to add pivot points or floor broker pivot points. Where can I find them with explanation of how to put them up? Thanks very much, Alan |
[2013-09-19 05:00:57] |
You really should read through the Getting Started page: http://www.sierrachart.com/index.php?l=doc/doc_GettingStarted.php#Introduction It answers these questions. Pivot Points is a study and is added as a study to the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
