Date/Time: Fri, 17 Jan 2025 19:28:11 +0000
CTS T4 Connection
View Count: 1486
[2017-12-26 05:08:34] |
User841161 - Posts: 232 |
As of now, I am only trading custom spreads with CTS T4. These spreads are not supported for trading, as of yet, through Sierra Charts. So is there any reason to have the $10 CTS Trading Connection enabled.
[2017-12-26 05:14:17] |
It does not sound like it. Is Global Settings >> Data/Trade Service Settings >> Service set to CTS T4 FIX? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-26 05:39:30] |
I have two Sierra Charts I can use. One of them usually has CTS T4 Fix Set, but usually cant use that because I have to have CTS T4 platform open and using CTS T4 connection and it cant use connection for both..
[2017-12-26 21:55:38] |
You can use both at the same time by setting Global Settings >> Data/Trade Service Settings >> Service Setting >> Perform Hardware ID Check to enabled/True.
