Date/Time: Fri, 17 Jan 2025 19:54:48 +0000
How can I export a study for initial balance like attached?
View Count: 1694
[2017-12-25 10:29:22]
User378082 - Posts: 33
Private File
[2017-12-27 18:23:03]
Update to the latest "Prerelease" following these instructions here:
Add the particular study you want to export to the chart. In this case it will be the Initial Balance study.
And use this command here on the Edit menu:
Edit Menu: Edit >> Export Bar and Study Data to Text File
Date Time Of Last Edit: 2017-12-28 05:56:59
[2017-12-28 04:52:36]
can I export it to excel file?
[2017-12-28 05:57:31]
No.
And also we updated the prior post to indicate that it is necessary to add the Initial Balance study to the chart.
[2017-12-29 12:39:20]
Whether I choose 1min or 1day, the following is just 0:
IB High Ext 4   IB High Ext 3   IB High Ext 2   IB High Ext 1   IB High   IB Mid   IB Low   IB Low Ext 1   IB Low Ext 2   IB Low Ext 3   IB Low Ext 4
I just don't know what's wrong with it?
attachmentCLg8 [C] Daily #2_GraphData.txt - Attached On 2017-12-29 12:37:50 UTC - Size: 483.64 KB - 481 views
Private File
[2017-12-29 21:20:32]
The first thing we want you to do is to update to the latest "Prerelease" as we instructed you to do previously. Here are the instructions:
This is essential.
