Date/Time: Fri, 17 Jan 2025 19:25:40 +0000
GDT_RENKO_WICK cannot be recognised in version 1674
View Count: 663
[2017-12-24 03:34:45] |
User841591 - Posts: 42 |
sc.BaseGraphGraphDrawType==GDT_RENKO_WICK works fine in the previous version of SC but now it would be "not declared" during compile after I updated SC to recent version. Pls advise what is the code replacement for GDT_RENKO_WICK for the recent version 1674
[2017-12-24 03:52:22] |
Check /ACS_Source/SCConstants.h: GDT_RENKO_BRICK_WITH_WICKS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
