Date/Time: Fri, 17 Jan 2025 19:29:27 +0000
Divergence study
View Count: 1183
[2017-12-22 16:02:42] |
User635423 - Posts: 51 |
Is there any divergence INDICATOR available, which will connect High-Low in Price chart and High Low in another indicator like MACD,RSI OR STOCHASTIC. Thanks |
[2017-12-22 19:00:05] |
There is the Divergence Detector study: Divergence Detector If it does not meet your requirements, then that is all we have. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-22 19:00:24
