Date/Time: Fri, 17 Jan 2025 15:24:36 +0000
Alert implementation on rectangle area breakout
View Count: 1083
[2017-12-21 17:36:37]
s291117 - Posts: 28
Hello support,
is there a way to trigger alerts when the price action goes outside of a zone designed manually with a rectangle ?
If the candle crosses below or above at close, then the alert would trigger.
This would allow to define accumulation zones and be informed when the price gets out.
https://gyazo.com/b2fd1d7d1677a41259998a91da55a3ec
We need more criterias such has: cross the upbar and the downbar of the rectangle.
Thanks for your precisions.
[2017-12-21 18:19:51]
Refer to the documentation here for Chart Drawing alerts:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartDrawingAlerts
