Date/Time: Sun, 24 Nov 2024 03:42:02 +0000
avoid reloading history
View Count: 1278
[2013-09-18 11:30:59] |
SKY - Posts: 45 |
i have few charts that use data of long history period each time I launch Sierracharts I need to wait 7-10 min. until all info is downloaded how can I avoid it so only the latest history (during the time Sierracharts was closed) will need to be downloaded (so trading platform will be ready for trading much faster) tnx |
[2013-09-18 19:40:15] |
Only the data that is missing from the charts is actually downloaded. The remaining data is read from your local storage. We recommend disabling antivirus/anti-malware software and using SSD drives. Refer to help topic 30 here: http://www.sierrachart.com/index.php?l=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
