Date/Time: Fri, 17 Jan 2025 15:11:04 +0000
[Programming Help] - ACSIL Study Crashing
View Count: 715
[2017-12-21 02:30:54]
User710890 - Posts: 23
Hi, I'm very new to c++, but have written other studies that work fine. This latest one however is a bit unstable.
I add the study, it works fine. If go to edit the study settings on the given chart in any way once it has been added, I get the crash attached.
Not sure if it is my poor knowledge of c++ or if I am missing a step on the SC end of things.
If it's not an SC thing, I will simply keep on digging as I know that is outside the scope of your support.
Thanks in advance.
Private File
Private File
Private File
[2017-12-21 16:27:34]
I resolved this by setting
sc.FreeDLL = 0;
Forgot that that should be set as such when using new and delete. Apologies!
