Date/Time: Fri, 17 Jan 2025 14:53:07 +0000
Lock Fill Space Custom distance
View Count: 2383
[2017-12-20 17:03:13]
s291117 - Posts: 28
i would like to know if it is possible to define a custom distance for the Lock Fill Space feature ? (charts settings 2)
See file attached just to give an overview about the result searched.
This would ease a lot when using small timeframes as the chart generates lot of visuals candles.
Thanks !
[2017-12-20 17:32:28]
Yes. Just set the space to what you require and then lock it.
Refer to:
Working With Charts: Locking the Right Side Fill Space
