Date/Time: Fri, 17 Jan 2025 14:58:41 +0000
Fractals Indictor or Study?
View Count: 2515
[2017-12-20 06:47:19] |
User585845 - Posts: 17 |
Is there an indicator or study that marks fractals on the chart? I am referring Bill Williams fractals which is a 5 bar pattern that represents swing highs and lows. Thanks.
Date Time Of Last Edit: 2017-12-20 07:01:13
[2017-12-20 12:54:53] |
Xfanman1 - Posts: 320 |
SC has the Bill Williams Fractals study. Bill Williams Fractal Signals Also check out the Swing High and Swing Low indicator. The default is arrows but you can change it to whatever you want to paint the indicator. You can also change the length to set how many minimum bars you want between swings. Swing High and Low Scott Date Time Of Last Edit: 2017-12-20 13:00:21
