Date/Time: Fri, 17 Jan 2025 15:10:36 +0000
Use Evening Sessions gets disabled
View Count: 908
[2017-12-19 17:23:29] |
User299392 - Posts: 216 |
Use Evening Session checkbox (under chart settings) gets disabled every time I bring up a new futures symbol from a quote board in the same chart linked to the quote board via chart linking feature. This is also when I save the chartbook after bringing up every future. And then next time I go back to it that chart would lose the use evening future checkbox and then I will have to again re check that box to populate use evening feature data. Please help; will really appreciate it please. |
[2017-12-19 17:37:40] |
I figured this myself. It was to do with global symbol settings. Close this ticket please. Ty! |
[2017-12-19 17:48:07] |
For reference, this is the relevant documentation: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
