Date/Time: Fri, 17 Jan 2025 15:01:36 +0000
Market Depth Historical Graph & VbP
View Count: 941
[2017-12-19 15:13:55] |
User98657 - Posts: 329 |
My MDHG studgy is covering up my previous day's volume profile unless i uncheck my VbP Draw Study Underneath Main Price Graph. Is there any way for me to layer the MDHG beneath my VbP or to force the previous day's bars to end prior to running under my VbP? |
[2017-12-19 16:27:40] |
This also applies to other drawings that i may want to place on the chart. A simple circle/ellipse for instance. I want to see those on top of the MDHG study, not buried beneath. Thanks. |
[2017-12-19 22:34:38] |
This is explained here: Chart Studies: Study Display Order In the case of chart drawings, how to control the order of them is explained here: Chart Drawing Tools: Controlling Display Order of Chart Drawings Relative to Graphs There are only two choices. Either below all of the graphs or above them. But you can also use transparency for those highlight drawings as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-19 22:57:17] |
Thank you! I had it reversed in my head thinking studies at top of the list took precedence, but i get it.
