Date/Time: Fri, 17 Jan 2025 14:55:21 +0000
values in spreadsheets not refreshing
View Count: 1063
[2017-12-19 13:36:35] |
User606491 - Posts: 164 |
I'm still having issues with values in spreadsheets that do not refresh. Are others having the same issues? I'm currently running. v.1671. thank you, |
[2017-12-19 17:12:04] |
This is very vague. We need a lot more details to understand this. Are you referring to the Spreadsheet Study and the associated Sheet it uses? Make sure you are looking at the correct Sheet within the Spreadsheet. Also refer to this particular Input setting with the Spreadsheet Study: Spreadsheet Study Inputs: Chart Data Output Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-19 17:12:48
[2017-12-19 18:47:17] |
Great point. You are right. More detail: This occurs when using the spreadsheet system for trading and using the study/price overlay with daily data. For example, I overlay daily data on a 15 minute chart. The daily values oftentimes will not refresh unless I manually refresh the daily chart. The issue is not that I have set match bar time periods to yes. |
[2017-12-19 22:29:44] |
We still need more precise details. When look at the values of the Study/Price Overlay on the chart itself, do you see that those differ from the values on the Sheet in the columns for that study? This is not something we would expect. If you are doing any calculations with the Study/Price Overlay study using other studies, you might have some issues with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
