Date/Time: Fri, 17 Jan 2025 15:09:21 +0000
[User Discussion] - Recreate an indicator
View Count: 989
[2017-12-18 19:14:42]
User465417 - Posts: 12
I wanted to recreate a very simple indicator from CQG called peak. http://help.cqg.com/cqgic/default.htm#!Documents/peakpeak.htm
Basically this is how it's calculated:
Calculation
Hi Peak = Highest Price with LLev (number) of lower highs preceding the Hi Peak and RLev (number) of lower highs following it.
Lo Peak = Lowest Price with LLev (number) of higher lows preceding the Lo Peak and RLev (number) of higher lows following it.
LLev
Determines the number of bars to the left of the Hi/Lo peak which must have a lower Hi/higher Lo.
RLev
Determines the number of bars to the right of the Hi/Lo peak which must have a lower Hi/higher Lo.
And I want to use the setting of 30 aka 30 bars for LLev and RLev.
Can anyone help me out?
[2017-12-19 16:50:52]
Bump please
[2017-12-19 17:24:13]
This is not within the scope of our support and is marked as a User Discussion.
