Date/Time: Fri, 17 Jan 2025 13:33:33 +0000
Ticks are off
View Count: 758
[2017-12-18 18:13:24] |
arrow - Posts: 52 |
I have not updated in a while. Updated from 1506 to 1669. My Renko ticks are off. A 5 tick CL chart for instance is no longer on 5's. The renko bars are 5 ticks while the actual tick is on 4's. A new bar starts at 56.94 and closes up at 56.99. This should be 56.95 - 57.00. Date Time Of Last Edit: 2017-12-18 18:24:51
[2017-12-18 18:42:40] |
This has changed. Refer to: Renko Bar Charts: Opening Price for First Renko Bar and Alignment (Aligned Renko Bars) You need to use Aligned Renko Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-18 18:43:40
