Date/Time: Thu, 23 Jan 2025 00:06:39 +0000
Chart studies in linked charts
View Count: 1537
[2017-12-18 17:45:20] |
User459170 - Posts: 262 |
Hi, chart studies (lines, rectangles, etc) in linked charts don't seem to show up with different timeframe charts. May be I am missing something. How to fix this?
Date Time Of Last Edit: 2017-12-18 17:46:14
[2017-12-18 18:07:09] |
Lines and rectangles are drawing tools: Chart Drawing Tools We are not clear what you are asking about here. You need to be more clear with us. A Chart Drawing on a chart is not going to disappear when the timeframe of the chart bars changes. If you want to copy chart drawings to other charts, then refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-18 18:20:05] |
Hi, Thanks, I have two charts (I duplicated the 30 min chart and changed the time on the duplicate to 5 min) of the same symbol, one 30 min and the other 5 min. Both are linked with link type "Link Chart studies/Graphs". If I draw a rectangle on the 30 min chart, is it not supposed to also show up on the 5 min chart? How do I get it to show up in both charts? Thanks.
Date Time Of Last Edit: 2017-12-18 18:21:48
[2017-12-18 19:30:04] |
Refer to this page for instructions to do what you want: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-18 20:59:48] |
I don't want to exactly copy chart drawings. I want whatever I draw on the 5 min chart to show up in the 1 min chart which is a linked chart. Is that possible? So at any given time, I would have both charts open and what I draw on one should show up on the other.
Date Time Of Last Edit: 2017-12-18 21:01:20
[2017-12-18 21:35:56] |
The feature does what you want. Read it again and follow through the instructions we linked to. It does what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-18 21:46:37] |
Awesome!! Thanks for your patience.
[2018-10-27 17:48:04] |
AE16 - Posts: 31 |
Hi guys, I have this set up but I cant seem to find out how to have the 'Chart Values Tool' mirrored between two charts (different time frame)? Thanks in advance.
[2018-10-29 21:06:06] |
This is called the Global Cursor setting: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 21:06:15
