Date/Time: Fri, 17 Jan 2025 15:04:26 +0000
Data missing from symbol reset CQG fix trading
View Count: 801
[2017-12-18 15:25:51]
User298178 - Posts: 8
I am missing a chunk of data still on everytime frame ...a delete and download fails ...this is kind of imperative
Private File
[2017-12-18 15:58:44]
now2 having the same problem with metals
[2017-12-18 17:42:18]
We have verified this issue was resolved.
Right-click somewhere on the chart, and select Delete and Download Data.
Date Time Of Last Edit: 2017-12-18 17:43:20
[2017-12-18 20:56:35]
Metals are still not working ...gaps in the data still ....crude still has gaps in the data as well..I did a symbol reset twice now ...still gaps in the data
Private File
Private File
[2017-12-18 21:30:22]
We are see you are running an older version of Sierra Chart at least on one of your systems.
Also those screenshots are not helpful to us. We will only accept a chart image by following these instructions here:
And we do not need any screenshots. We never asked for one.
Update to the current version following these instructions here:
We also forgot to ask from you that after you follow the procedure in post #3 above, to provide us the Message Log by following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
We also need to be clear with you about one other thing. You have posted messages through account support tickets and numerous threads on the support board about this issue. Start only one support request and no others. We are going to start deleting all of those postings and not responding.
And once again we want to confirm, this issue was resolved and there simply should not be a problem.
Date Time Of Last Edit: 2017-12-18 21:32:38
[2017-12-18 22:43:47]
If you are still having a problem at this point, it is best we use remote assistance to help you.
We did try calling you yesterday but there was no answer.
