Date/Time: Fri, 17 Jan 2025 15:05:54 +0000
Disable Auto Trading from Global Profit /Loss
View Count: 816
[2017-12-18 07:48:08] |
User169205 - Posts: 67 |
hello.. in 'global p/l management', would it be possible to add an option to 'disable auto trading' if p/l rules have been met ? currently, if 'lock trading' has been engaged, my trading system will place orders on the chart and the positions will immediately be flattened if triggered.. this causes unwanted commission charges and skewed trading results. thanks |
[2017-12-18 07:53:23] |
Yes we will do that. Should be out in a couple of days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-18 21:49:48] |
thank you !!
