Date/Time: Sun, 24 Nov 2024 04:59:10 +0000
CTS FIX error messages......
View Count: 1933
[2013-09-17 20:23:54] |
User14266 - Posts: 225 |
I am not experiencing problems, but I am seeing strange errors in the log. Any thoughts? Thanks. CTS FIX: Received FIX message does not have the expected message sequence number. Expected 963407, but received 963408. | 2013-09-17 15:08:50 FIX Message: 8=FIX.4.29=81635=W34=96340849=PTP56=SierraChart50=T4FIX52=20130917-20:08:48.50655=ES48=CME_20131200_ESZ3207=CME_Eq387=1405732965=2268=21269=0270=169800271=17751023=1269=0270=169775271=14251023=2269=0270=169750271=12621023=3269=0270=169725271=18701023=4269=0270=169700271=19391023=5269=0270=169675271=20571023=6269=0270=169650271=21731023=7269=0270=169625271=9541023=8269=0270=169600271=13621023=9269=0270=169575271=10781023=10269=1270=169825271=5831023=1269=1270=169850271=13151023=2269=1270=169875271=13901023=3269=1270=169900271=15421023=4269=1270=169925271=9431023=5269=1270=169950271=13661023=6269=1270=169975271=15201023=7269=1270=170000271=15051023=8269=1270=170025271=10141023=9269=1270=170050271=10901023=10269=4270=169825271=110=039 | 2013-09-17 15:08:50 CTS FIX: Requesting missing messages starting with sequence number 963407 | 2013-09-17 15:08:50 CTS FIX: Received FIX message does not have the expected message sequence number. Expected 963408, but received 963409. | 2013-09-17 15:08:50 FIX Message: 8=FIX.4.29=81535=W34=96340949=PTP56=SierraChart50=T4FIX52=20130917-20:08:48.50655=ES48=CME_20130900_ESU3207=CME_Eq387=710085965=2268=21269=0270=170475271=3031023=1269=0270=170450271=14821023=2269=0270=170425271=10341023=3269=0270=170400271=10241023=4269=0270=170375271=13691023=5269=0270=170350271=13561023=6269=0270=170325271=13751023=7269=0270=170300271=9901023=8269=0270=170275271=13131023=9269=0270=170250271=9491023=10269=1270=170500271=2201023=1269=1270=170525271=15531023=2269=1270=170550271=15441023=3269=1270=170575271=14351023=4269=1270=170600271=15141023=5269=1270=170625271=13891023=6269=1270=170650271=11721023=7269=1270=170675271=11511023=8269=1270=170700271=12641023=9269=1270=170725271=15331023=10269=4270=170500271=1610=047 | 2013-09-17 15:08:50 CTS FIX: Requesting missing messages starting with sequence number 963408 | 2013-09-17 15:08:50 CTS FIX: Ignored message while waiting for FIX message resend. FIX Message: 8=FIX.4.29=9235=434=96340749=PTP56=SierraChart50=T4FIX52=20130917-20:08:48.66343=Y36=963410123=Y10=088 | 2013-09-17 15:08:50 CTS FIX: Ignored message while waiting for FIX message resend. FIX Message: 8=FIX.4.29=81535=W34=96341049=PTP56=SierraChart50=T4FIX52=20130917-20:08:48.75655=ES48=CME_20130900_ESU3207=CME_Eq387=710085965=2268=21269=0270=170475271=3031023=1269=0270=170450271=14821023=2269=0270=170425271=10341023=3269=0270=170400271=10241023=4269=0270=170375271=13691023=5269=0270=170350271=13561023=6269=0270=170325271=13751023=7269=0270=170300271=9901023=8269=0270=170275271=13131023=9269=0270=170250271=9491023=10269=1270=170500271=2201023=1269=1270=170525271=15531023=2269=1270=170550271=15441023=3269=1270=170575271=14351023=4269=1270=170600271=15141023=5269=1270=170625271=13891023=6269=1270=170650271=11721023=7269=1270=170675271=11511023=8269=1270=170700271=12641023=9269=1270=170725271=15331023=10269=4270=170500271=1610=046 | 2013-09-17 15:08:50 CTS FIX: Remote side sent a Sequence Reset <4> message. Next expected sequence number is now 963411. | 2013-09-17 15:08:50 |
[2013-09-17 20:25:11] |
Also, Should I have FIX logging enabled? I am using FIX, obviously. |
[2013-09-17 21:20:00] |
You can disregard these messages. The CTS system may be dropping some market data messages and then the sequence number gets automatically reset.
