Date/Time: Fri, 17 Jan 2025 13:45:02 +0000
Bitmex connection
View Count: 826
[2017-12-17 05:18:26] |
User699005 - Posts: 7 |
Broken connection
Date Time Of Last Edit: 2017-12-17 05:19:43
8976ะต.PNG / V - Attached On 2017-12-17 05:19:39 UTC - Size: 58.52 KB - 316 views |
[2017-12-17 05:23:55] |
What you seem to be describing is missing data. Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-17 05:24:14
