Date/Time: Fri, 17 Jan 2025 15:19:04 +0000
[User Discussion] - Pip value
View Count: 1365
[2017-12-16 19:03:59]
EuropeanTrader - Posts: 290
I would like to calculate desired fx trading lot size for my trades.
For that I would need to include in my spreadsheet study a value of the selected currency pair tick value.
How can I do that, please?
Thank you!
[2017-12-19 09:58:46]
Can I expect an answer to this?
Thank you
[2017-12-19 13:44:49]
Sawtooth - Posts: 4154
Currency value per tick is in cell J56.
[2017-12-19 14:22:51]
Hi Tom,
I noticed it but it is not correct as I see it. Maybe I am missing something but 1 pip value per 100 k lot is far different for EURGBP than for USDJPY for example and J56 does not show it.
So I thought maybe there is a place for customizing it in data feed settings or something.
[2017-12-19 14:23:16]
I am using SC Data All services.
[2017-12-19 15:28:53]
You can change the default currency value per tick here:
Global Settings >> Symbol Settings
Here's the documentation:
Global Symbol Settings
For the spreadsheet to show an updated setting, you'll need to choose a different symbol, then choose the original symbol.
[2017-12-19 17:14:49]
O uau. Thank you Tom ! I appreciate it a lot
