Date/Time: Fri, 17 Jan 2025 13:55:56 +0000
Price details sensitive to cursor location?
View Count: 862
[2017-12-14 18:21:05] |
nth - Posts: 46 |
Across the top of a 30 min bar chart shows the last, change, HLCO, vol, bid, ask, etc. I recall a time when this, or something like it, would be sensitive to where the cross hair cursor was currently located. Where might I find how to set that up, again, assuming I'm not having creative memories. ;) Best, nth |
[2017-12-14 22:13:07] |
Refer to the documentation here for this: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
