Date/Time: Sun, 24 Nov 2024 05:03:28 +0000
Correct Time Settings
View Count: 1300
[2013-09-17 18:14:41] |
User57072 - Posts: 49 |
Is this the correct settings for the daily cattle market at CME? Intra Day Chart Intraday bar Periods Bar Period Type Days-Minutes-Seconds Per Bar 1-0-0 Session Times start time: 09:05:00 end time: 04:00:00 |
[2013-09-17 19:11:19] |
Please check with the CME website.
