Date/Time: Fri, 17 Jan 2025 13:35:06 +0000
Standard Deviations
View Count: 1931
[2017-12-14 15:13:37] |
User28682 - Posts: 233 |
How can I get SC's standard deviation study to show me how many SD's price is above MY OWN MOVING AVERAGE? Ex: I would like to see how many SD's price is above a 200period moving average. Thanks! |
[2017-12-14 17:53:05] |
That study calculates the standard deviation from an Input Data series. You can then use that result for whatever you want. Maybe these studies might be helpful: Using the Basic Arithmetic Studies You will have to figure out to do what you want. If you want us to work on that, we can do that at 50 USD per hour. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-14 17:54:05
