Date/Time: Fri, 17 Jan 2025 13:50:19 +0000
drawing from another chart
View Count: 625
[2017-12-14 14:54:40] |
User163689 - Posts: 29 |
if you have auto draw from another chart is there a way to change or delete some lines but not effect main chart?
[2017-12-14 17:49:44] |
Not if the Chart Drawings were copied from another chart. Definitely not.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-14 17:49:55
