Date/Time: Fri, 17 Jan 2025 13:42:41 +0000
FIX API
View Count: 1014
[2017-12-14 14:30:23] |
milenmitzik - Posts: 27 |
How could I connect Sierra to some institutional platforms as Integral, Flextrade, SmartTrade etc. For FX spot. If ordering such a connection which would be the price? Date Time Of Last Edit: 2017-12-14 14:31:59
[2017-12-14 17:43:00] |
FIX is not highly standardized. The connection to each one of these would have to be custom programmed. We might be able to do something like this, in a few months but not at the moment. It is hard to say what the cost would be but probably not less than 5000 USD for a connection. If you just require market data it would be less than 1000USD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-14 17:43:32
