Date/Time: Fri, 17 Jan 2025 14:01:30 +0000
confuse about data feed
View Count: 1111
[2017-12-14 09:55:01] |
User245723 - Posts: 6 |
hai..i have a look on list data feed from sierra chart..but i'm still confuse..can u suggest me which datafeed is good for me?i like to use CQG datafeed so the price is 33usd + 10-20usd for sierra chart full platform with CQG data feed right?but CQG need account and i dont know how to register CQG account.. For your information im trade currencies only..i want to use real time market depth level 2 data and footprint(number bar)..can u suggest for me good market depth data feed for forex..thanks sir |
[2017-12-14 18:27:52] |
Did you want to chart and trade Forex futures? Who is your futures broker? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-16 08:58:48] |
i want to use depth of market on spot fx..and i have no brooker right now support sierra chart..so im confuse which package and data feed i need to active so i try read on support board and many use LMAX data feed for spot fx.. so for package 5 is 33usd + how much for LMAX? |
[2017-12-16 21:30:18] |
Market depth data for spot Forex is currently only available through LMAX if you have an account with them. Otherwise, you will not have access to the market depth data. But we can give you access to their demo data feed if that would be acceptable for you. There is no cost for this. But it will expire after 30 days but we can add it again for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-17 05:02:58] |
So means any account LMAX can link for spot fx market depth real-time streaming? Demo and live is different data right? Can i try demo first before subcribe? |
[2017-12-17 05:36:10] |
The answer to all of this is yes. ---- Hello, A LMAX trading account has now been assigned to your Sierra Chart account. The particular account number assigned to your Sierra Chart account can be viewed on this page: https://www.sierrachart.com/UserControlPanel.php If this account number is one that you provided us, verify it is correct. Update Sierra Chart to the current version following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Set "Global Settings >> Data/Trade Service Settings >> Service" to "LMAX Demo Trading - DTC". Connect to the server with "File >> Connect to Data Feed". Depending upon when you receive this message it may take up to two minutes for our server to receive the updated authorizations for you to be able to connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
