Date/Time: Sat, 18 Jan 2025 11:11:57 +0000
Charting or trade symbols that not included in Symbol list
View Count: 1242
[2017-12-14 08:07:23]
User841591 - Posts: 42
I am using IB which can provide trade and quote for Hong Kong stock. It seems HK stock are not included in SC symbol list. Pls advise if it is possible to import the quotes to SC by IB or text file or any alternative.
[2017-12-14 17:46:34]
Stock symbols are not listed. You just need to manually enter them through File >> Find Symbol.
Refer to this page for instructions:
Interactive Brokers Symbols
Here are the stock symbol formats:
Interactive Brokers Symbols: Stock Format
[2018-02-12 20:04:46]
FFTrader - Posts: 180
I tried using the proper format - for example, stock symbol 0001 - I tried using
1. 0001-STK-SMART/SEHK
2. 0001-STK-SEHK
Both does not seems to be loading at all?
[2018-02-13 00:08:58]
First thing to do is contact Interactive Brokers about this:
Interactive Brokers Symbols: Contacting Interactive Brokers Support for Symbol Specifications
[2018-02-14 02:21:27]
The correct symbol is 1-STK-SEHK-HKD
