Date/Time: Fri, 17 Jan 2025 07:15:01 +0000
GetBasicSymbolDataWithDepthSupport function
View Count: 815
[2017-12-13 22:33:49]
User840509 - Posts: 4
Hi!
1) The method GetBasicSymbolDataWithDepthSupport is mentioned here:
sc.GetBasicSymbolDataWithDepthSupport
However that method is not found in any of the headers at ACS_Source folder. Can you explain why?
2)my goal is to use that method in order to receive DoM data of multiple symbols. Is there an alternative to that function?
Regards,
Dima.
[2017-12-14 00:45:12]
The problem is you are running an older version. Update:
