Date/Time: Sun, 24 Nov 2024 03:46:18 +0000
Add new Functions & datafeed
View Count: 1375
[2013-09-17 16:07:28] |
crazybears - Posts: 314 |
Hi Sierra Chart Engineering i know you are very busy , so please excuse me for these requests ,when you have time maybe and if is possible ,you could add it to the function list,they would be very useful . 1) Number Bars calculated Values 2) something to recognize in the sc.VolumeAtPriceForBars if at that price there is a Peak or Valley ,maybe something like true or false 3)could you consider to add in the data feed that you are developed the NYMEX ,maybe only CL :) i think would be very attractive for many traders ;) which could choose SC as a complete platform |
[2013-09-17 23:37:45] |
1. This is not easily accomplished. 2. This is not practical to be added for efficiency reasons and does not seem like it would make sense for a single chart bar. 3. All symbols on the CME will be included in the upcoming CME data feed including NYMEX markets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-18 13:09:47] |
Hi 1) ok 2) ok , i meant for searching Peaks and valleys on VaP ,set for example on 90 days . but if i understand how they are drawn i could try to make it. http://www.sierrachart.com/supportboard/showthread.php?t=28837&page=2&highlight=peaks+valleys at post #50 For a value of 3, just look 3 levels up and down, and if the level is the extreme of those 7 levels, then it would be a peak/valley.
it mean the peak must be the greatest value among the seven values , another comparison among lesser values it has not been done . value 2 could be minor than value 3 , does it?could be added in the Volume Graph Period Type selection : From Start date-Time To previous Time , so automatically VbP is calculated from the start date-Time to the previous computer date-time ) Great :) |
