Date/Time: Fri, 17 Jan 2025 07:24:49 +0000
User Question
View Count: 833
[2017-12-13 16:46:51] |
Sierra Chart - Max - Posts: 5779 |
I expect I will be able to get ES from Infinity, which is the only futures symbol I want. I also would like stocks traded on the NYSE and NASDAQ. The cash indexes are also of interest, specifically Dow Jones Industrials, S&P 500, Nasdaq Composite, and Russell 2000. Finally, I would like NYSE internals (specifically, advancers, decliners, up volume, and down volume). Ideally I would also like to be able to create spread charts (GS/JPM, AAPL/GOOG, etc.), which I think your software can do anyway, though I have not started using it, yet. Thank you, Sierra Chart Support |
[2017-12-13 20:49:24] |
Do you just require historical data for stocks and indexes? Or do you need historical and real-time data? Based on your requirements you will need a direct Sierra Chart account: Direct Sierra Chart Account If you require real-time stock and index data data you will also need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Market statistics are included: Sierra Chart Market Statistics Spreads are supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
