Date/Time: Sun, 13 Sep 2026 16:30:03 +0000
inv reference type question
View Count: 2205
| [2013-09-17 15:43:09] |
| gabby alindogan - Posts: 49 |
Hi Trying to pick the highest hi for past 10 bars with a 1 bar offset. This means current bar's value would be highest high of the past 10 bars starting with the bar to the left. I tried creating array "PrevHi" to load high 1 bar back then use gethighest function on it. Can you please tell me my error using this code? The DLL error I am getting is Starting build of Custom Studies Source File: Fx.cpp. -- 11:34:43 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\Fx.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\Fx.dll" C:\SierraChart\ACS_Source\Fx.cpp: In function 'void scsf_CapPoints(SCStudyInterfaceRef)': C:\SierraChart\ACS_Source\Fx.cpp:42:60: error: invalid initialization of reference of type 'SCFloatArrayRef {aka c_ArrayWrapper<float>&}' from expression of type 'float' SCFloatArrayRef PrevHi = sc.BaseData[SC_HIGH][sc.Index-1 ]; ^ -- End of Build -- 11:34:44 SCSFExport scsf_CapPoints(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.GraphName = "Capitulation Points " ; sc.Subgraph[0].Name = "Cap Points (20D)> "; sc.AutoLoop=1; sc.FreeDLL = 1; return; } SCFloatArrayRef PrevHi = sc.BaseData[SC_HIGH][sc.Index-1 ]; float HighestxBB = sc.GetHighest(PrevHi, 10); 10 barssc.Subgraph[0][sc.Index] =HighestxBB; return; } SCSFExport scsf_CapPoints(SCStudyInterfaceRef sc) { // Section 1 - Set the configuration variables if (sc.SetDefaults) { sc.GraphName = "Capitulation Points " ; sc.Subgraph[0].Name = "Cap Points (20D)> "; sc.AutoLoop=1; sc.FreeDLL = 1; return; } SCFloatArrayRef PrevHi = sc.BaseData[SC_HIGH][sc.Index-1 ]; float HighestxBB = sc.GetHighest(PrevHi, 10); sc.Subgraph[0][sc.Index] =HighestxBB; return; } |
| [2013-09-17 19:21:25] |
float HighestxBB = sc.GetHighest(sc.BaseData[SC_HIGH], 10); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-09-17 19:42:12] |
The code you detailed plots the highest high past 10 days BUT does not offset by 1 bar i.e. sc.index-1. The indicator needs to plot the highest high past 10 bars excluding the current bar which is still in process of completing. I tried to change your line by adding an offset and I got errors. Orig> float HighestxBB = sc.GetHighest(sc.BaseData[SC_HIGH], 10); Changed to > float HighestxBB = sc.GetHighest(sc.BaseData[SC_HIGH][sc.Index-1], 10); Error log follows C:\SierraChart\ACS_Source\Fx.cpp: In function 'void scsf_CapPoints(SCStudyInterfaceRef)': C:\SierraChart\ACS_Source\Fx.cpp:47:72: error: no matching function for call to 's_sc::GetHighest(float&, int)' float HighestxBB = sc.GetHighest(sc.BaseData[SC_HIGH][sc.Index-1], 10); ^ C:\SierraChart\ACS_Source\Fx.cpp:47:72: note: candidates are: In file included from C:\SierraChart\ACS_Source\Fx.cpp:2:0: C:\SierraChart\ACS_Source\sierrachart.h:3008:8: note: float s_sc::GetHighest(SCFloatArrayRef, int, int) float GetHighest(SCFloatArrayRef In, int Index, int Length) ^ C:\SierraChart\ACS_Source\sierrachart.h:3008:8: note: candidate expects 3 arguments, 2 provided C:\SierraChart\ACS_Source\sierrachart.h:3025:8: note: float s_sc::GetHighest(SCFloatArrayRef, int) float GetHighest(SCFloatArrayRef In, int Length) ^ C:\SierraChart\ACS_Source\sierrachart.h:3025:8: note: no known conversion for argument 1 from 'float' to 'SCFloatArrayRef {aka c_ArrayWrapper<float>&}' -- End of Build -- 15:39:54 |
| [2013-09-19 01:50:02] |
We really have limited time with to help with this. We recommend contacting Onn here: https://www.sierrachart.com/index.php?l=doc/SierraChartStudyAndSystemProgrammers.html#ThirdPartyList Also, the easiest way to accomplish an offset is by using the Displacement setting on the Study Subgraph in the Study Settings window for the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-19 01:51:53
| [2013-09-19 01:55:10] |
This is what you want to use: float HighestxBB = sc.GetHighest(sc.BaseData[SC_HIGH],sc.Index-1, 10); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
