Date/Time: Fri, 17 Jan 2025 07:20:56 +0000
modifying Chart Shortcut Menu-- Market Profile Options
View Count: 699
[2017-12-12 17:13:57] |
User11638 - Posts: 21 |
I would like to remove some Market Profile Options on the Chart Shortcut Menu, but when I go to Global Settings --> Customize Chart Shortcut Menu, the Market Profile-related menu selections do not appear on the list. How would I go about modifying these menu options? I would like to delete a couple of them. Thank you. |
[2017-12-12 17:40:38] |
Those particular TPO Profile Chart commands cannot be changed.
