Date/Time: Fri, 17 Jan 2025 07:37:49 +0000
draw horizontal line from the mid of a candle
View Count: 1090
[2017-12-12 10:10:02] |
User226486 - Posts: 27 |
Hi Sierra, Is there a way to automate a draw horizontal line from the mid of a candle between a specific time range. Also the horizontal line extended to be always on the chart ive managed to create the horizontal line using either h/l avg, auto retacement or initial balance but dont know how to extend the line to be always showing. please help? many thanks |
[2017-12-12 18:16:29] |
Use the Horizontal Line at Time study: Horizontal Line at Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 18:23:50] |
Tried that but how do I make the horizontal line shown on the chart infinite, not just till intersection or till new one is made the next day. I would like each day to have a new line which is infinite on chart. Hope that makes sense. Thanks |
[2017-12-12 19:01:01] |
For this you are going to need to create your own custom study. Refer to: Advanced Custom Study Interface and Language (ACSIL) You might want to even use Ray drawings for this: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-12 19:02:16
[2017-12-12 19:04:25] |
Ok, thanks will look into it!
