Date/Time: Sun, 24 Nov 2024 03:38:43 +0000
horizontal line
View Count: 1687
[2013-09-17 14:23:58]
mayerrs - Posts: 70
hi, i would like to ask you about horizontal line. do you think there would be possible to make what i describe on pic?
thanks
imageHorizontal line.png / V - Attached On 2013-09-17 14:23:26 UTC - Size: 62.01 KB - 493 views
[2013-09-19 01:57:16]
Yes. Depending upon exactly what you want to do, you could use the Spreadsheet study or ACSIL:
https://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudy.html
[2013-09-19 02:17:30]
Sawtooth - Posts: 4118
Support, would you please consider outputting the Currency Value Per Tick (J56) to the Spreadsheet Study and the Spreadsheet System/Alert studies?
[2013-09-19 04:34:27]
You can use the Spreadsheet Study study, give it a name in the Spreadsheet Name field, set the Chart Region to 1, set the Number of Rows to 10, and put the formula in K3. Then use the Text Display For Study study to display the value on the chart.
=($E$3-$H$1)*100*10
where
E3 is the Last
H1 is the support line value
[2013-09-19 12:32:50]
mayerrs - Posts: 70
thanks for help. it works but it is unuseful for me. i do have too many chartbooks and too many charts in each chartbook. i do have 18 chartbooks and 32 chart in 1chartbook, 16charts in 1chartbook and 6charts in 16chartbooks. so it is a huge mess when i try to do it by this way. i was wondering about something useful and much more simple. could it be this option part of horizontal line propertis? it is much more simple.
[2013-09-19 22:25:08]
M5amhan - Posts: 468
i know this isnt exactly what you are asking for but i tend to use the chart calculator draw tool for this: http://www.sierrachart.com/image.php?l=1379629424387.png
it is useful and gives me the tick difference and currency value of the move.. hope it helps the cause
[2013-09-20 05:18:01]
mayerrs - Posts: 70
you are right and i also use chart calculator every day but in so many charts and and chartbooks i have i was wondering about something more productive. and that would be great if would be the actuall currency difference right on the support or resistnace.
thank you anyway
