Date/Time: Fri, 17 Jan 2025 07:36:05 +0000
Auto center on DOM
View Count: 4436
[2017-12-12 01:54:24] |
User157806 - Posts: 71 |
Just checking to see if there is an auto center function for the DOM? I tried checking Re-Center trade dome scales from the "Trade" menu on the DOM but it seems to only work just once and is not constant.
[2017-12-12 03:51:45] |
Yes. Open the Scale Settings as described here: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph And use this Constant Range Scale Mode: Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center To The Last Price On Every Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 03:56:52] |
This is just for the charts correct? Not for the DOM?
[2017-12-12 04:02:47] |
It is for both.
[2017-12-12 04:10:31] |
Ok great thank you.
