Date/Time: Fri, 17 Jan 2025 07:29:06 +0000
Symbol for Poloniex Bitcoin/USD
View Count: 917
[2017-12-11 13:22:00] |
User626121 - Posts: 82 |
Hi, can you please tell me the exact symbol for Poloniex BTC/USD? Couldn't find it in the symbol search. Thanks |
[2017-12-11 19:03:37] |
Global Settings >> Data/Trade Service Settings >> Service needs to be set to SC Data - All Services. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings The closest symbol we see is this: USDT_BTC-PLNX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-11 19:04:01
