Date/Time: Fri, 17 Jan 2025 07:15:19 +0000
is it possible to have access of "CandleStick Patterns Finder"?
View Count: 710
[2017-12-11 04:16:45] |
User271989 - Posts: 44 |
is it possible to have access of "CandleStick Patterns Finder"? thanks in advance |
[2017-12-11 06:08:15] |
The source code is in /ACS_Source/Studies4.cpp Refer to: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Or are you just looking to use the study? Did you want the source code? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-11 06:08:52
