Date/Time: Fri, 17 Jan 2025 14:03:12 +0000
Access to "Draw Outline Only ( Hollow)" setting via s_useTool
View Count: 1113
[2017-12-10 16:12:29]
User700756 - Posts: 16
I am trying to draw a circle using s_UseTool. I want to use MARKER_POINT and access the "Draw Outline Only" option like is available on the tool config settings.
I have read the documentation, searched the support board and otherwise attempted to figure out how to access this setting with s_UseTool and it appears it is not available without configuring
I want to draw a hollow circle of size X, with the center at ( BarIndex, Price ). I May need to draw multiple circles at the same BarIndex and I can't know ahead of time how many so this prevents me from using a Subgraph[] with DRAWSTYLE_CIRCLE_HOLLOW.
Can you please advise if this is possible or point me to other relevant documentation that I may have overlooked?
thanks,
[2017-12-10 20:44:24]
This is not supported. Other than by using Subgraphs.
But there is the Marker tool which has different Styles. But not a hollow circle.
We will see if we can support this though.
Date Time Of Last Edit: 2017-12-10 20:45:54
[2017-12-10 20:45:58]
Prior post has been updated.
[2017-12-10 20:59:15]
I was able to get what i needed by drawing the marker with "tool.UseToolConfigNum" set to a tool config that has the "Draw Outline Only (Hollow)" parameter checked. Then I just re-drew the same drawing without "tool.UseToolConfigNum" set and i was able to adjust the circle to the size I wanted.
If it was supported to just access that "Draw Outline Only" setting within s_UseTool it would be cleaner.
thanks,
[2017-12-11 18:06:02]
OK we did not even recognize that particular option for the Marker tool. We apologize for that.
Yes we will add Draw Outline Only to s_UseTool.
[2017-12-12 06:11:13]
If you are going to do that could you add the option for Transparent Fill also?
[2017-12-15 10:17:56]
No, this is not reasonably possible.
