Date/Time: Fri, 17 Jan 2025 07:18:47 +0000
Strange problem with tools bar
View Count: 708
[2017-12-10 14:28:31] |
fjgaspar - Posts: 62 |
Hi, Today, when I have opened sierra charts, I have seen a very strange thing: the tools bar, which always used to be a thin horizontal bar under Menu bar, with icons for different tools, and with a small rectangle on the left showing the state of the connection, is now a wide (it ocuppies almost half of screen), and no icon is showed. Just the connection status at the left, and a big grey bar. What can be happening and how to solve it? |
[2017-12-10 20:40:30] |
Refer to the instructions here for this: Control Bar: Control Bar Buttons Too Large This problem relates tto some unusual behavior with Windows 10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-10 20:40:54
[2017-12-10 20:49:22] |
Thanks for the help. Restart the computer has solved the problem.
[2017-12-10 20:56:01] |
That is interesting. If this solved the problem, this is clearly unstable behavior on the part of Windows 10.
