Date/Time: Fri, 17 Jan 2025 07:33:43 +0000
year high
View Count: 719
[2017-12-10 08:17:28] |
jonno - Posts: 13 |
Hi Is it possible to get a year high/low and difference to last quote in the quote board or quote spreadsheet. I cannot see how. Thanks John |
[2017-12-10 09:39:00] |
This can be done by using this study: Previous/Period OHLC-Variable Period And then using the Study Subgraphs difference study: Study Subgraphs Subtract/Difference To calculate the difference between the year High/Low to the Last/Close price of the chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-10 09:39:15
