Date/Time: Sun, 24 Nov 2024 04:37:54 +0000
suggestions
View Count: 1422
[2013-09-17 10:20:34] |
AKR - Posts: 523 |
hi, I have two suggestions, but nothing really important. 1) when it comes to Graphics Settings it would be great to have at least two "templates". A dark one (as it is) and a light one with white background and all the other colors automatically adjusted to fit. doing each oneself is quite inconvenient 2) would be great if it was possible to add "submenues" when customizing the shortcut menue. so one could make a submenue eg. drawings and then put in all frequently needed drawing tools. otherwise this menue can become quite long and "unclear" rgrds, alexander |
[2013-09-17 11:13:11] |
1. You can do this now through settings specific to individual charts. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html 2. OK, but it is not something we can do. We have too many other things. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
