Date/Time: Fri, 17 Jan 2025 07:19:11 +0000
missing bars
View Count: 1343
[2017-12-09 17:14:46]
User170575 - Posts: 221
Hi---so using 1 minute bars in a spreadsheet---and missing a bar at 2017-12-06 13:24:00--as well as a few
others---the bar is also missing on the chart---so maybe a data issue? No volume on the ES--not likely?
Any easy fix---maybe to make sure the bar exits even without volume?
Many thanks,
Cy
image1324missing bar.jpg / V - Attached On 2017-12-09 17:11:50 UTC - Size: 19.37 KB - 278 views
[2017-12-09 17:36:52]
this should work---thank you
"If you want to have bars in the chart for periods of time where there is no trading, then enable the Include Columns with No Data option in the Chart >>Chart Settings."
[2017-12-09 17:45:57]
It does help to have the continuous contract enabled!
[2017-12-09 21:01:52]
Let us know if you need more help.
If the data is actually missing when it should not be, then refer to:
Date Time Of Last Edit: 2017-12-09 21:02:07
