Date/Time: Fri, 17 Jan 2025 07:37:21 +0000
Spreadsheet "copy value"
View Count: 1204
[2017-12-09 16:14:06]
User170575 - Posts: 221
Hi--I would like to be able to just copy the values(without references/formulas)--then paste these values to sheet2 and do a sort---all of the commands are there---"copy value" and "sort" but the references are pasted making the sort obsolete.
Thoughts appreciated,
Cy
[2017-12-10 22:28:56]
This issue has already been solved. You just need to update Sierra Chart to the current version.
[2017-12-13 16:57:12]
I very, very much appreciate your effort but there are issues still--I am on version 1663
[2017-12-13 18:55:45]
We do not see any problems when we select Spreadsheet >> Copy Value and paste the values aand other cells with Spreadsheet >> Paste. Only the values are pasted. This is clear.
[2017-12-13 19:32:02]
try a sort
[2017-12-13 19:41:26]
Describe the exact step-by-step procedure you are following. Just make this as simple as possible involving 2 cells.
We do not see the relevancy of the sort. Just the values are copied and not the formulas.
Date Time Of Last Edit: 2017-12-13 19:41:46
[2017-12-13 19:59:14]
I select the data---copy---paste to an added sheet---then I sort it---the data disappears or the sort does not start from the highest selected cell in the column--there are blank cells in my data just for the record
[2017-12-13 20:37:06]
Make sure you use Spreadsheet >> Copy Value to copy the values.
We have done a sort and we see no trouble with this whatsoever.
Try copying and sorting just a few values like 5. That is how we are doing the test. See if you have any trouble with that.
Date Time Of Last Edit: 2017-12-13 20:37:30
