Date/Time: Fri, 17 Jan 2025 07:23:13 +0000
Is there a way to alter the distance between columns on a numbers bar chart?
View Count: 965
[2017-12-08 22:29:16] |
User781967 - Posts: 18 |
I use two columns -- Column 1 is bid x ask and Column 2 is Ask Vol Bid Vol Difference. Column 2 is one number and Column 1 is two numbers. Is there a way to put them closer together to save space? Thanks.
[2017-12-11 18:02:39] |
You are only able to change the Bar Spacing: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
