Date/Time: Fri, 17 Jan 2025 07:12:45 +0000
Bot with a candlestick pattern and moving average on bitmex
View Count: 1762
[2017-12-08 21:21:33] |
User271989 - Posts: 44 |
1 - I want to use a Bot with a candlestick pattern and moving average on bitmex. What I need for this? Can I without being a coder make a system like in metastock? 2- on the main trading page bitmex have charts without delay but if i choose "open in a new window" the charts have 1 delay. Trading a Bot using Sierra the system will use the charts as fast as the charts in the main trading page? 3- the system can run in a vps? Thanks in advance |
[2017-12-08 23:20:05] |
1. What you are referring to is automated trading. Refer to: Automated Trading Management 2. We do not understand this because there is no command in Sierra Chart with the name: "open in a new window". Sierra Chart automated trading is very fast. 3. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-08 23:21:38
