Date/Time: Fri, 17 Jan 2025 05:58:01 +0000
Recent change in Numbers Bars text coloring method
View Count: 930
[2017-12-08 15:43:32]
User707408 - Posts: 6
I have been using Text Coloring on Diagonal Dominant Side AskVol BidVol Percentage. I understand that you have made a change recently consisting in coloring of non-dominant side by default color. Previously I was used to observe also how much non-dominant the non-dominant side was, i.e. I used different colors for Ask Percentage/Bid Percentage smaller than 0.3 and bigger than 0.3, which is no more possible. Do you think it could be solved, e.g. by adding new text coloring method based on diagonal AskVol BidVol percentage?
[2017-12-08 18:22:43]
Yes we will do this.
